Hier asterisk:
-- Executing Set("SIP/AH-b6803378", "MDC_CHANNEL_PROTOCOL=SIP") in new stack
-- Executing Set("SIP/AH-b6803378", "MDC_CHANNEL_ID=AH-b6803378") in new stack
-- Executing Set("SIP/AH-b6803378", "MDC_CHANNEL_TMP=AH-b6803378") in new stack
-- Executing Set("SIP/AH-b6803378", "MDC_CHANNEL_NAME=AH") in new stack
-- Executing GosubIf("SIP/AH-b6803378", "1?mdc_initcall-int|71|1") in new stack
-- Executing NoOp("SIP/AH-b6803378", "initial call") in new stack
-- Executing Set("SIP/AH-b6803378", "__MDC_DIALDESCENT=int") in new stack
-- Executing Set("SIP/AH-b6803378", "__MDC_DIALCALLEENUM=71") in new stack
-- Executing Set("SIP/AH-b6803378", "__MDC_DIALCALLERNUM=44") in new stack
-- Executing GotoIf("SIP/AH-b6803378", "1?nozap") in new stack
-- Goto (mdc_initcall-int,71,8)
-- Executing Set("SIP/AH-b6803378", "__MDC_DIALCALLERNAME=44 AH") in new stack
-- Executing Return("SIP/AH-b6803378", "") in new stack
-- Executing Gosub("SIP/AH-b6803378", "mdc_defcall|71|1") in new stack
-- Goto (mdc_defcall,71,4)
-- Executing Set("SIP/AH-b6803378", "__MDC_DIALCHANNELNAME=AH") in new stack
-- Executing SIPAddHeader("SIP/AH-b6803378", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing Macro("SIP/AH-b6803378", "pre-main") in new stack
Nov 5 14:29:43 WARNING[5015]: app_macro.c:208 macro_exec: No such context 'macro-pre-main' for macro 'pre-main'
-- Executing GosubIf("SIP/AH-b6803378", "1?mdc_initloop|s|1") in new stack
-- Executing NoOp("SIP/AH-b6803378", "initial loop") in new stack
-- Executing Set("SIP/AH-b6803378", "MDC_ALIAS_HOP=0") in new stack
-- Executing Goto("SIP/AH-b6803378", "main|71|1") in new stack
-- Goto (main,71,1)
-- Executing Set("SIP/AH-b6803378", "_MDC_VOICEMAIL=71") in new stack
-- Executing Set("SIP/AH-b6803378", "_MDC_WATCHED_VOICEMAIL=0") in new stack
-- Executing Goto("SIP/AH-b6803378", "mdc_ident-23|71|1") in new stack
-- Goto (mdc_ident-23,71,1)
-- Executing NoOp("SIP/AH-b6803378", "alias-check:: Rufumleitung von 71 - 0") in new stack
-- Executing GotoIf("SIP/AH-b6803378", "0?71-umleitung|1:71-dial|1") in new stack
-- Goto (mdc_ident-23,71-dial,1)
-- Executing Gosub("SIP/AH-b6803378", "mdc_prefix-71-int|71|1") in new stack
-- Executing Gosub("SIP/AH-b6803378", "mdc_main-71-int|71|1") in new stack
-- Executing Dial("SIP/AH-b6803378", "SIP/Wireless1||o") in new stack
-- Called Wireless1
-- SIP/Wireless1-081ea130 is circuit-busy
== Everyone is busy/congested at this time (1:0/1/0)
-- Executing Gosub("SIP/AH-b6803378", "mdc_suffix-71-int|71|1") in new stack
-- Executing Hangup("SIP/AH-b6803378", "1") in new stack
== Spawn extension (mdc_ident-23, 71-dial, 4) exited non-zero on 'SIP/AH-b6803378'
