Ich habe das nun in meinen Ämterketten bei ausgehenden Regel eingetragen jedoch ohne erfolg.
anbei der Auszug aus der CLI
Connected to Asterisk 11.6-cert2 currently running on MobyDick (pid = 1460)
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
[Oct 17 11:07:44] ERROR[1765][C-00000116]: chan_sip.c:33122 setup_srtp: No SRTP module loaded, can’t setup SRTP session.
– Executing [0015129152476@mdc_location-4:1] Verbose(“SIP/SNOM02-0000030c”, “1,Wolfgang Peuker”) in new stack
Wolfgang Peuker
– Executing [0015129152476@mdc_location-4:2] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_LOCATION_ID=4”) in new stack
– Executing [0015129152476@mdc_location-4:3] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_LOCATION_NAME=Wolfgang Peuker”) in new stack
– Executing [0015129152476@mdc_location-4:4] Gosub(“SIP/SNOM02-0000030c”, “sub_location,s,1(4,0015129152476)”) in new stack
– Executing [s@sub_location:1] Verbose(“SIP/SNOM02-0000030c”, “1,used location id: 4 - dialed extension: 0015129152476”) in new stack
– Executing [s@sub_location:2] Set(“SIP/SNOM02-0000030c”, “MDC_CALLEE_NUM=0015129152476”) in new stack
– Executing [s@sub_location:3] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [0015129152476@mdc_location-4:5] Gosub(“SIP/SNOM02-0000030c”, “sub_split-location,s,1(4)”) in new stack
– Executing [s@sub_split-location:1] Verbose(“SIP/SNOM02-0000030c”, “1,get user for location: 4”) in new stack
– Executing [s@sub_split-location:2] GotoIf(“SIP/SNOM02-0000030c”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-location:3] Set(“SIP/SNOM02-0000030c”, “TMP_USER_ID=4”) in new stack
– Executing [s@sub_split-location:4] Verbose(“SIP/SNOM02-0000030c”, “1,user id: 4”) in new stack
user id: 4
– Executing [s@sub_split-location:5] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [0015129152476@mdc_location-4:6] Goto(“SIP/SNOM02-0000030c”, “mdc_user-4,0015129152476,1”) in new stack
– Goto (mdc_user-4,0015129152476,1)
– Executing [0015129152476@mdc_user-4:1] Verbose(“SIP/SNOM02-0000030c”, “1,wpeuker”) in new stack
wpeuker
– Executing [0015129152476@mdc_user-4:2] Gosub(“SIP/SNOM02-0000030c”, “sub_user,s,1(caller,4,21,wpeuker,Wolfgang Peuker,21,21,21)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/SNOM02-0000030c”, “1,sub_user mode caller”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/SNOM02-0000030c”, “s-caller,1”) in new stack
– Goto (sub_user,s-caller,1)
– Executing [s-caller@sub_user:1] Verbose(“SIP/SNOM02-0000030c”, “1,sub_user user id: 4 - user exten: 21 - user: wpeuker - realname: Wolfgang Peuker - own mailbox: 21 - watched mailbox: 21 - callerid(num): 21”) in new stack
– Executing [s-caller@sub_user:2] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_USER_ID=4”) in new stack
– Executing [s-caller@sub_user:3] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_NUM=21”) in new stack
– Executing [s-caller@sub_user:4] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_ACC_NAME=wpeuker”) in new stack
– Executing [s-caller@sub_user:5] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_ACC_REALNAME=Wolfgang Peuker”) in new stack
– Executing [s-caller@sub_user:6] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_VM_OWN=21”) in new stack
– Executing [s-caller@sub_user:7] Set(“SIP/SNOM02-0000030c”, “__MDC_CALLER_VM_WATCHED=21”) in new stack
– Executing [s-caller@sub_user:8] Set(“SIP/SNOM02-0000030c”, “CALLERID(name)=Wolfgang Peuker”) in new stack
– Executing [s-caller@sub_user:9] Set(“SIP/SNOM02-0000030c”, “CALLERID(num)=21”) in new stack
– Executing [s-caller@sub_user:10] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [0015129152476@mdc_user-4:3] Goto(“SIP/SNOM02-0000030c”, “internal,0015129152476,1”) in new stack
– Goto (internal,0015129152476,1)
– Executing [0015129152476@internal:1] SIPAddHeader(“SIP/SNOM02-0000030c”, ““Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing [0015129152476@internal:2] GosubIf(“SIP/SNOM02-0000030c”, “1?sub_initcall,s,1(int,0015129152476)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/SNOM02-0000030c”, “1,sub_initcall descent: int exten: 0015129152476”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/SNOM02-0000030c”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/SNOM02-0000030c”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/SNOM02-0000030c”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/SNOM02-0000030c”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALDESCENT=int”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/SNOM02-0000030c”, “int,1”) in new stack
– Goto (sub_initcall,int,1)
– Executing [int@sub_initcall:1] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLERNUMINIT=21”) in new stack
– Executing [int@sub_initcall:2] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLEENUMINIT=0015129152476”) in new stack
– Executing [int@sub_initcall:3] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLEENUMMAP=0015129152476”) in new stack
– Executing [int@sub_initcall:4] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [0015129152476@internal:3] Goto(“SIP/SNOM02-0000030c”, “main,0015129152476,1”) in new stack
– Goto (main,0015129152476,1)
– Executing [0015129152476@main:1] Gosub(“SIP/SNOM02-0000030c”, “sub_defcall,s,1(0015129152476)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/SNOM02-0000030c”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLEENUM=0015129152476”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLERNUM=21”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/SNOM02-0000030c”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCALLERNAME=Wolfgang Peuker”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/SNOM02-0000030c”, “__MDC_DIALCHANNELNAME=SNOM02”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [0015129152476@main:2] Goto(“SIP/SNOM02-0000030c”, “mdc_distribute,0015129152476,1”) in new stack
– Goto (mdc_distribute,0015129152476,1)
– Executing [0015129152476@mdc_distribute:1] Set(“SIP/SNOM02-0000030c”, “MDC_INPREFIX_TRUNK=0”) in new stack
– Executing [0015129152476@mdc_distribute:2] Verbose(“SIP/SNOM02-0000030c”, “1,remove inprefix: 0”) in new stack
remove inprefix: 0
– Executing [0015129152476@mdc_distribute:3] Goto(“SIP/SNOM02-0000030c”, “mdc_outgoing-16,015129152476,1”) in new stack
– Goto (mdc_outgoing-16,015129152476,1)
– Executing [015129152476@mdc_outgoing-16:1] Gosub(“SIP/SNOM02-0000030c”, “sub_failover-outgoing-16,015129152476,1”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:1] Set(“SIP/SNOM02-0000030c”, “TMP_CALLERIDNUM=”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:2] Gosub(“SIP/SNOM02-0000030c”, “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,015129152476,00,49,0,9852)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/SNOM02-0000030c”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 015129152476 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 9852”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/SNOM02-0000030c”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/SNOM02-0000030c”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/SNOM02-0000030c”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/SNOM02-0000030c”, " 0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/SNOM02-0000030c”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“SIP/SNOM02-0000030c”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“SIP/SNOM02-0000030c”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“SIP/SNOM02-0000030c”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/SNOM02-0000030c”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/SNOM02-0000030c”, “MDC_CALLEE_NUM_INTERNAT=004915129152476”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:3] Gosub(“SIP/SNOM02-0000030c”, “sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,004915129152476,00,49,0,9852)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/SNOM02-0000030c”, “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 004915129152476 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 9852”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/SNOM02-0000030c”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/SNOM02-0000030c”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/SNOM02-0000030c”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/SNOM02-0000030c”, “MDC_CALLEE_NUM_NAT=015129152476”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/SNOM02-0000030c”, “”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:4] Set(“SIP/SNOM02-0000030c”, “CALLERID(num)=”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:5] UserEvent(“SIP/SNOM02-0000030c”, “ResolveCallerName,Strategy: default,Outbound: 1,Channel: SIP/SNOM02-0000030c”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:6] Wait(“SIP/SNOM02-0000030c”, “0.25”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:7] Verbose(“SIP/SNOM02-0000030c”, “1,MDC_RESOLVENAME_HITS = 1”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:8] Verbose(“SIP/SNOM02-0000030c”, “1,MDC_DIALCALLEENAME = Wolfgang Peuker”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:9] Verbose(“SIP/SNOM02-0000030c”, “1,SipGate Line 0 - Standardtelefonie”) in new stack
– Executing [015129152476@sub_failover-outgoing-16:10] Dial(“SIP/SNOM02-0000030c”, “SIP/mdc_trunk_conf-2/015129152476,t”) in new stack
– Called SIP/mdc_trunk_conf-2/015129152476
– SIP/mdc_trunk_conf-2-0000030d is making progress passing it to SIP/SNOM02-0000030c
– SIP/mdc_trunk_conf-2-0000030d is ringing
== Spawn extension (sub_failover-outgoing-16, 015129152476, 10) exited non-zero on ‘SIP/SNOM02-0000030c’
– Executing [h@sub_failover-outgoing-16:1] Gosub(“SIP/SNOM02-0000030c”, “def_hangup,s,1(,CANCEL,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/SNOM02-0000030c”, “>>>def_hangup:: EXTEN: DIALSTATUS: CANCEL QUEUESTATUS: REASON: CALL”) in new stack
MobyDick*CLI>
