Hallo Pascom-Profis!
Ich habe folgende Meldung sobald ich die Telefonkonfig aktualisiere auf der CLI stehen:
ca. 50 mal diese Meldung:
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of ‘_.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1704 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1705 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1706 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1707 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1708 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1713 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1714 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1715 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1716 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘X.’ instead at line 1717 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of '.’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘_X.’ instead at line 1722 of /etc/asterisk/mdc_extensions.conf
und dann ebenfalls immer wieder sehr oft das gleiche:
[Jun 14 16:40:56] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 1 in ‘mdc_mapping-17’, already in use
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1813 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:56] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 2 in ‘mdc_mapping-17’, already in use
[Jun 14 16:40:56] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1814 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 1 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1839 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 2 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1840 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 1 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1841 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 2 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1842 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 1 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1843 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 2 in ‘mdc_mapping-12’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1844 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1845 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1846 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘_498868268999X.’ priority 1 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1881 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘_498868268999X.’ priority 2 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1882 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘_498868268999X.’ priority 3 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1883 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘4989xxxxxxx629’ priority 1 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1898 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘4989xxxxxxx629’ priority 2 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1899 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 1 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1904 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 2 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1905 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 1 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1906 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 2 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1907 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 1 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1908 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 2 in ‘mdc_mapping-3’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1909 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1910 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1911 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1912 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1913 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1914 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1915 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 1 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1946 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘+4989xxxxxxx629’ priority 2 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1947 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 1 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1948 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘089xxxxxxx629’ priority 2 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1949 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 1 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1950 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘89xxxxxxx629’ priority 2 in ‘mdc_mapping-15’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1951 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 1952 of /etc/asterisk/mdc_extensions.conf
Woran kann das liegen?
Ich habe, bis es mal funktioniert hat, sehr viel experimentieren müssen und da waren sicher auch alle Varianten diese Nummer zu schreiben dabei,
allerdings ist jetzt EINE funktionierende Konfiguration für diesen Trunk in der Anlage (jedenfalls funktionieren momentan alle Ämter so wie vorgesehen).
Warum jetzt die gleiche Fehlermeldung mehrfach auftaucht und in allen Schreibweisen kann ich mir nicht erklären.
Es betrifft auch nur diese eine Nummer aus dem Trunk (Fax-Nr.)
Dann kommen nochmal ca. 30 gleiche Fehlermeldungen:
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘[+*%#a-zA-Z0-9].’ priority 1 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2759 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension '[+%#a-zA-Z0-9].’ priority 2 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2760 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension '_[+%#a-zA-Z0-9].’ priority 3 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2761 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘[+*%#a-zA-Z0-9].’ priority 4 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2762 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension '[+%#a-zA-Z0-9].’ priority 1 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2764 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension '_[+%#a-zA-Z0-9].’ priority 2 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2765 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension ‘[+*%#a-zA-Z0-9].’ priority 3 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2766 of /etc/asterisk/mdc_extensions.conf
[Jun 14 16:40:57] WARNING[17123]: pbx.c:7144 add_priority: Unable to register extension '[+*%#a-zA-Z0-9].’ priority 4 in ‘mdc_outgoing’, already in use
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1891 pbx_load_config: Unable to register extension at line 2767 of /etc/asterisk/mdc_extensions.conf
sowie am Ende folgendes:
[Jun 14 16:40:57] WARNING[17123]: pbx_config.c:1879 pbx_load_config: The use of ‘_!’ for an extension is strongly discouraged and can have unexpected behavior. Please use ‘_X!’ instead at line 3922 of /etc/asterisk/mdc_extensions.conf
Diese Schreibweisen habe ich auch nirgendwo verwendet.
Ich kann nicht genau sagen ob das mit jeder Speicherung der Konfig mehr wurde oder sich anderweitig erhöht hat.
Wie bekomme ich das wieder in Griff?
