Aus Extention: habe ich nun: ${EXTEN:-1}${EXTEN:-1}
gemacht da ich aus der 4 am ende der Rufnummer ja die 44 machen muss.
Ich habe nun endlich die Logfiles:
== Using SIP RTP CoS mark 5
– Executing [4920899397444@mdc_incoming-3:1] Set(“SIP/mdc_trunk_conf-3-00000000”, “MDC_CALLER_NUM_TRUNK=016090579868”) in new stack
– Executing [4920899397444@mdc_incoming-3:2] Macro(“SIP/mdc_trunk_conf-3-00000000”, “mdc_deterdest,MDC_CALLEE_NUM_TRUNK,<sip:004920899397444@sipconnect.sipgate.de>”) in new stack
– Executing [s@macro-mdc_deterdest:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,macro-mdc_deterdest:: variable: MDC_CALLEE_NUM_TRUNK header: <sip:004920899397444@sipconnect.sipgate.de>”) in new stack
– Executing [s@macro-mdc_deterdest:2] Set(“SIP/mdc_trunk_conf-3-00000000”, "TMP_DN=004920899397444@sipconnect.sipgate.de>") in new stack
– Executing [s@macro-mdc_deterdest:3] Set(“SIP/mdc_trunk_conf-3-00000000”, “TMP_DN=004920899397444”) in new stack
– Executing [s@macro-mdc_deterdest:4] Set(“SIP/mdc_trunk_conf-3-00000000”, “MDC_CALLEE_NUM_TRUNK=004920899397444”) in new stack
– Executing [4920899397444@mdc_incoming-3:3] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,destination 004920899397444 is extracted”) in new stack
– Executing [4920899397444@mdc_incoming-3:4] Goto(“SIP/mdc_trunk_conf-3-00000000”, “mdc_trunk-3,s,1”) in new stack
– Goto (mdc_trunk-3,s,1)
– Executing [s@mdc_trunk-3:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,callee number: 004920899397444 caller number: 016090579868”) in new stack
– Executing [s@mdc_trunk-3:2] GosubIf(“SIP/mdc_trunk_conf-3-00000000”, “0?sub_internat,s,1(CALLERID(num),016090579868,00)”) in new stack
– Executing [s@mdc_trunk-3:3] Gosub(“SIP/mdc_trunk_conf-3-00000000”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,016090579868,00,49,0,208)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): 016090579868 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 208”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/mdc_trunk_conf-3-00000000”, “MDC_CALLER_NUM_INTERNAT=004916090579868”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/mdc_trunk_conf-3-00000000”, “”) in new stack
– Executing [s@mdc_trunk-3:4] Set(“SIP/mdc_trunk_conf-3-00000000”, “CALLERID(num)=004916090579868”) in new stack
– Executing [s@mdc_trunk-3:5] Gosub(“SIP/mdc_trunk_conf-3-00000000”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004916090579868,00,49,0,208)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004916090579868 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 208”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/mdc_trunk_conf-3-00000000”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/mdc_trunk_conf-3-00000000”, “MDC_CALLER_NUM_NAT=016090579868”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/mdc_trunk_conf-3-00000000”, “”) in new stack
– Executing [s@mdc_trunk-3:6] Set(“SIP/mdc_trunk_conf-3-00000000”, “CALLERID(num)=016090579868”) in new stack
– Executing [s@mdc_trunk-3:7] Gosub(“SIP/mdc_trunk_conf-3-00000000”, “sub_pb-search,s,1(CALLERID(name),016090579868,016090579868,004916090579868,+4916090579868)”) in new stack
– Executing [s@sub_pb-search:1] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,sub_pb-search variable: CALLERID(name) calleridnum: 016090579868 national: 016090579868 international: 004916090579868 +internat: +4916090579868”) in new stack
[Jul 16 11:01:22] NOTICE[6150]: res_odbc.c:1527 odbc_obj_connect: Connecting md
[Jul 16 11:01:22] NOTICE[6150]: res_odbc.c:1559 odbc_obj_connect: res_odbc: Connected to md [md]
> Found no rows [SELECT “028pho_bez”, “028pho_firstname”, “028pho_lastname”, “028pho_organisation” FROM “028phonebook” WHERE “028pho_phone”=‘016090579868’ OR “028pho_phone”=‘016090579868’ OR “028pho_phone”=‘004916090579868’ OR “028pho_phone”=’+4916090579868’ OR “028pho_homephone”=‘016090579868’ OR “028pho_homephone”=‘016090579868’ OR “028pho_homephone”=‘004916090579868’ OR “028pho_homephone”=’+4916090579868’ OR “028pho_mobile”=‘016090579868’ OR “028pho_mobile”=‘016090579868’ OR “028pho_mobile”=‘004916090579868’ OR “028pho_mobile”=’+4916090579868’]
– Executing [s@sub_pb-search:2] Set(“SIP/mdc_trunk_conf-3-00000000”, “HASH(PB_ENTRY)=”) in new stack
– Executing [s@sub_pb-search:3] Verbose(“SIP/mdc_trunk_conf-3-00000000”, “1,”) in new stack
-- Executing [s@sub_pb-search:4] Verbose("SIP/mdc_trunk_conf-3-00000000", "1,") in new stack
-- Executing [s@sub_pb-search:5] Verbose("SIP/mdc_trunk_conf-3-00000000", "1,") in new stack
-- Executing [s@sub_pb-search:6] Verbose("SIP/mdc_trunk_conf-3-00000000", "1,") in new stack
-- Executing [s@sub_pb-search:7] Set("SIP/mdc_trunk_conf-3-00000000", "CALLERID(name)=") in new stack
-- Executing [s@sub_pb-search:8] Return("SIP/mdc_trunk_conf-3-00000000", "") in new stack
-- Executing [s@mdc_trunk-3:8] Set("SIP/mdc_trunk_conf-3-00000000", "MDC_NUMPREFIX_TRUNK=") in new stack
-- Executing [s@mdc_trunk-3:9] Goto("SIP/mdc_trunk_conf-3-00000000", "mdc_mapping-3,004920899397444,1") in new stack
-- Goto (mdc_mapping-3,004920899397444,1)
[Jul 16 11:01:22] WARNING[6150]: pbx.c:5119 __ast_pbx_run: Channel ‘SIP/mdc_trunk_conf-3-00000000’ sent into invalid extension ‘004920899397444’ in context ‘mdc_mapping-3’, but no invalid handler
