Nach Update auf 7.06.02 keine ausgehenden Anrufe möglich
nach dem Update der Firmware ist das Telefonieren nicht mehr möglich.
Eingehende Telefonate funktionieren korrekt.
beim Versuch gibt asterisk -r folgendes aus:
  == Using SIP RTP CoS mark 5
  == Extension Changed 21[mdc_hint-ident] new state InUse for Notify User Vd7TCqkm326581e
    -- Executing [03837847720@mdc_location-8:1] Verbose("SIP/privat-0000000c", "1,Privat") in new stack
 Privat
    -- Executing [03837847720@mdc_location-8:2] Set("SIP/privat-0000000c", "__MDC_CALLER_LOCATION_ID=8") in new stack
    -- Executing [03837847720@mdc_location-8:3] Set("SIP/privat-0000000c", "__MDC_CALLER_LOCATION_NAME=Privat") in new stack
    -- Executing [03837847720@mdc_location-8:4] Gosub("SIP/privat-0000000c", "sub_location,s,1(8,03837847720)") in new stack
    -- Executing [s@sub_location:1] Verbose("SIP/privat-0000000c", "1,used location id: 8 - dialed extension: 03837847720") in new stack
    -- Executing [s@sub_location:2] Set("SIP/privat-0000000c", "MDC_CALLEE_NUM=03837847720") in new stack
    -- Executing [s@sub_location:3] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@mdc_location-8:5] Gosub("SIP/privat-0000000c", "sub_split-location,s,1(8)") in new stack
    -- Executing [s@sub_split-location:1] Verbose("SIP/privat-0000000c", "1,get user for location: 8") in new stack
    -- Executing [s@sub_split-location:2] GotoIf("SIP/privat-0000000c", "0?s-zero,1") in new stack
    -- Executing [s@sub_split-location:3] Set("SIP/privat-0000000c", "TMP_USER_ID=10") in new stack
    -- Executing [s@sub_split-location:4] Verbose("SIP/privat-0000000c", "1,user id: 10") in new stack
 user id: 10
    -- Executing [s@sub_split-location:5] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@mdc_location-8:6] Goto("SIP/privat-0000000c", "mdc_user-10,03837847720,1") in new stack
    -- Goto (mdc_user-10,03837847720,1)
    -- Executing [03837847720@mdc_user-10:1] Verbose("SIP/privat-0000000c", "1,Privat") in new stack
 Privat
    -- Executing [03837847720@mdc_user-10:2] Gosub("SIP/privat-0000000c", "sub_user,s,1(caller,10,21,Privat,Privat,21,21,21)") in new stack
    -- Executing [s@sub_user:1] Verbose("SIP/privat-0000000c", "1,sub_user mode caller") in new stack
    -- Executing [s@sub_user:2] Goto("SIP/privat-0000000c", "s-caller,1") in new stack
    -- Goto (sub_user,s-caller,1)
    -- Executing [s-caller@sub_user:1] Verbose("SIP/privat-0000000c", "1,sub_user user id: 10 - user exten: 21 - user: Privat - realname: Privat - own mailbox: 21 - watched mailbox: 21 - callerid(num): 21") in new stack
    -- Executing [s-caller@sub_user:2] Set("SIP/privat-0000000c", "__MDC_CALLER_USER_ID=10") in new stack
    -- Executing [s-caller@sub_user:3] Set("SIP/privat-0000000c", "__MDC_CALLER_NUM=21") in new stack
    -- Executing [s-caller@sub_user:4] Set("SIP/privat-0000000c", "__MDC_CALLER_ACC_NAME=Privat") in new stack
    -- Executing [s-caller@sub_user:5] Set("SIP/privat-0000000c", "__MDC_CALLER_ACC_REALNAME=Privat") in new stack
    -- Executing [s-caller@sub_user:6] Set("SIP/privat-0000000c", "__MDC_CALLER_VM_OWN=21") in new stack
    -- Executing [s-caller@sub_user:7] Set("SIP/privat-0000000c", "__MDC_CALLER_VM_WATCHED=21") in new stack
    -- Executing [s-caller@sub_user:8] Set("SIP/privat-0000000c", "CALLERID(name)=Privat") in new stack
    -- Executing [s-caller@sub_user:9] Set("SIP/privat-0000000c", "CALLERID(num)=21") in new stack
    -- Executing [s-caller@sub_user:10] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@mdc_user-10:3] Goto("SIP/privat-0000000c", "internal,03837847720,1") in new stack
    -- Goto (internal,03837847720,1)
    -- Executing [03837847720@internal:1] SIPAddHeader("SIP/privat-0000000c", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
    -- Executing [03837847720@internal:2] GosubIf("SIP/privat-0000000c", "1?sub_initcall,s,1(int,03837847720)") in new stack
    -- Executing [s@sub_initcall:1] Verbose("SIP/privat-0000000c", "1,sub_initcall descent: int exten: 03837847720") in new stack
    -- Executing [s@sub_initcall:2] GosubIf("SIP/privat-0000000c", "1?sub_initloop,s,1") in new stack
    -- Executing [s@sub_initloop:1] Verbose("SIP/privat-0000000c", "1,initial loop") in new stack
 initial loop
    -- Executing [s@sub_initloop:2] Set("SIP/privat-0000000c", "MDC_ALIAS_HOP=0") in new stack
    -- Executing [s@sub_initloop:3] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [s@sub_initcall:3] Set("SIP/privat-0000000c", "__MDC_DIALDESCENT=int") in new stack
    -- Executing [s@sub_initcall:4] Goto("SIP/privat-0000000c", "int,1") in new stack
    -- Goto (sub_initcall,int,1)
    -- Executing [int@sub_initcall:1] Set("SIP/privat-0000000c", "__MDC_DIALCALLERNUMINIT=21") in new stack
    -- Executing [int@sub_initcall:2] Set("SIP/privat-0000000c", "__MDC_DIALCALLEENUMINIT=03837847720") in new stack
    -- Executing [int@sub_initcall:3] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@internal:3] Goto("SIP/privat-0000000c", "main,03837847720,1") in new stack
    -- Goto (main,03837847720,1)
    -- Executing [03837847720@main:1] Gosub("SIP/privat-0000000c", "sub_defcall,s,1(03837847720)") in new stack
    -- Executing [s@sub_defcall:1] Set("SIP/privat-0000000c", "__MDC_ALIAS_HOP=1") in new stack
    -- Executing [s@sub_defcall:2] Set("SIP/privat-0000000c", "__MDC_DIALCALLEENUM=03837847720") in new stack
    -- Executing [s@sub_defcall:3] Set("SIP/privat-0000000c", "__MDC_DIALCALLERNUM=21") in new stack
    -- Executing [s@sub_defcall:4] Set("SIP/privat-0000000c", "__MDC_DIALCHANNELNAME=privat") in new stack
    -- Executing [s@sub_defcall:5] GotoIf("SIP/privat-0000000c", "1?nozap") in new stack
    -- Goto (sub_defcall,s,8)
    -- Executing [s@sub_defcall:8] Set("SIP/privat-0000000c", "__MDC_DIALCALLERNAME=Privat") in new stack
    -- Executing [s@sub_defcall:9] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@main:2] Goto("SIP/privat-0000000c", "mdc_distribute,03837847720,1") in new stack
    -- Goto (mdc_distribute,03837847720,1)
    -- Executing [03837847720@mdc_distribute:1] Set("SIP/privat-0000000c", "MDC_INPREFIX_TRUNK=") in new stack
    -- Executing [03837847720@mdc_distribute:2] Verbose("SIP/privat-0000000c", "1,remove inprefix: ") in new stack
 remove inprefix:
    -- Executing [03837847720@mdc_distribute:3] Goto("SIP/privat-0000000c", "mdc_outgoing-3,03837847720,1") in new stack
    -- Goto (mdc_outgoing-3,03837847720,1)
    -- Executing [03837847720@mdc_outgoing-3:1] Gosub("SIP/privat-0000000c", "sub_trunk-outgoing-3,03837847720,1") in new stack
    -- Executing [03837847720@sub_trunk-outgoing-3:1] Gosub("SIP/privat-0000000c", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,03837847720,00,49,0,3647)") in new stack
    -- Executing [s@sub_nat2int:1] Verbose("SIP/privat-0000000c", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - CALLERID(num): 03837847720 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3647") in new stack
    -- Executing [s@sub_nat2int:2] GotoIf("SIP/privat-0000000c", "0?s-int,1") in new stack
    -- Executing [s@sub_nat2int:3] GotoIf("SIP/privat-0000000c", "0?s-int,1") in new stack
    -- Executing [s@sub_nat2int:4] GotoIf("SIP/privat-0000000c", "0?s-intshort,1") in new stack
    -- Executing [s@sub_nat2int:5] GotoIf("SIP/privat-0000000c", "0?s-natshort,1") in new stack
    -- Executing [s@sub_nat2int:6] GotoIf("SIP/privat-0000000c", "1?s-nat,1") in new stack
    -- Goto (sub_nat2int,s-nat,1)
    -- Executing [s-nat@sub_nat2int:1] Verbose("SIP/privat-0000000c", "1,national") in new stack
 national
    -- Executing [s-nat@sub_nat2int:2] Set("SIP/privat-0000000c", "MDC_CALLEE_NUM_INTERNAT=00493837847720") in new stack
    -- Executing [s-nat@sub_nat2int:3] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@sub_trunk-outgoing-3:2] Gosub("SIP/privat-0000000c", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00493837847720,00,49,0,3647)") in new stack
    -- Executing [s@sub_int2nat:1] Verbose("SIP/privat-0000000c", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00493837847720 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3647") in new stack
    -- Executing [s@sub_int2nat:2] GotoIf("SIP/privat-0000000c", "0?nat") in new stack
    -- Executing [s@sub_int2nat:3] GotoIf("SIP/privat-0000000c", "1?s-internat,1") in new stack
    -- Executing [s-internat@sub_int2nat:1] Set("SIP/privat-0000000c", "MDC_CALLEE_NUM_NAT=03837847720") in new stack
    -- Executing [s-internat@sub_int2nat:2] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@sub_trunk-outgoing-3:3] SIPAddHeader("SIP/privat-0000000c", "P-Preferred-Identity: sip:493647462921@sipconnect.sipgate.de") in new stack
    -- Executing [03837847720@sub_trunk-outgoing-3:4] Verbose("SIP/privat-0000000c", "1,bachstein - Standardtelefonie") in new stack
    -- Executing [03837847720@sub_trunk-outgoing-3:5] Dial("SIP/privat-0000000c", "SIP/mdc_trunk_conf-3/03837847720,,t") in new stack
[Apr  4 12:28:58] WARNING[5068][C-00000009]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
    -- Executing [03837847720@sub_trunk-outgoing-3:6] Return("SIP/privat-0000000c", "") in new stack
    -- Executing [03837847720@mdc_outgoing-3:2] Hangup("SIP/privat-0000000c", "19") in new stack
  == Spawn extension (mdc_outgoing-3, 03837847720, 2) exited non-zero on 'SIP/privat-0000000c'
    -- Executing [h@mdc_outgoing-3:1] Gosub("SIP/privat-0000000c", "def_hangup,s,1(,CHANUNAVAIL,,CALL)") in new stack
    -- Executing [s@def_hangup:1] NoOp("SIP/privat-0000000c", ">>>def_hangup:: EXTEN:  DIALSTATUS: CHANUNAVAIL QUEUESTATUS:  REASON: CALL") in new stack
  == Extension Changed 21[mdc_hint-ident] new state Idle for Notify User Vd7TCqkm326581e (queued)
Was bedeutet
Bitte um schnelle Hilfe.
Hallo Tolan,
es scheint als ob die Anlage NICHT bei deinem SIP Amt registriert ist bzw. registrien kann.
Hast Du einmal die Anlage durchgestartet ?
Maik
Hallo maik,
ja bereits 10 mal neu gestartet.
Bei sipgate Trunking steht online und eingehende Rufe laufen wie immer.
Hab gerade noch dies entdeckt:
die letzten beiden Einträge sind sehr unklar.
Habe bereits mehrmals gestartet.
Guten Morgen,
zu den letzten Einträgen im Updater.
Kannst du bitte mal auf der Shell die Version überprüfen. Hierzu bitte mal dpkg -l ex* ausführen und cat /firmware. Interessant ist hier dann, welche Version dort für die Firmware gelistet ist.
Hi Markus,
dpkg -l ex* ergibt
||/ Name Version Beschreibung
ii ex-asterisk 2.03.00.R Asterisk Binaries
ii ex-jnetdahdi 1.00.00.R DAHDI kernel modules
iF ex-mobydick 2.05.00.R Appliance firmware
ii ex-util 1.00.00.R Essex command line tools
ii ex-vmwaretools 1.01.00.R VMware kernel modules
un exim <keine> (keine Beschreibung vorhanden)
un exim-tls <keine> (keine Beschreibung vorhanden)
un exim4 <keine> (keine Beschreibung vorhanden)
ii exim4-base 4.72-6+squeeze support files for all Exim MTA (v4) packages
ii exim4-config 4.72-6+squeeze configuration for the Exim MTA (v4)
un exim4-config-2 <keine> (keine Beschreibung vorhanden)
un exim4-daemon-c <keine> (keine Beschreibung vorhanden)
un exim4-daemon-h <keine> (keine Beschreibung vorhanden)
ii exim4-daemon-l 4.72-6+squeeze lightweight Exim MTA (v4) daemon
un exim4-doc-html <keine> (keine Beschreibung vorhanden)
un exim4-doc-info <keine> (keine Beschreibung vorhanden)
un exim4-localsca <keine> (keine Beschreibung vorhanden)
un eximon4 <keine> (keine Beschreibung vorhanden)
un extlinux <keine> (keine Beschreibung vorhanden)
un exutil <keine> (keine Beschreibung vorhanden)
und cat /firmware
2.05.00.R
Hallo Tolan,
um die Firmware korrekt zu installieren, müsstest du noch einen reboot nach dem Update durchführen. Hast du das gemacht und steht dann immernoch iF bei ex-mobydick?
Hallo Tolan,
was du auch versuchen könntest, wäre bei den SIP-Optionen des Amtes “nat=yes” einzutragen. Zumindest hier hat das weitergeholfen.
