Externe Anrufe funktionieren nicht und IVR schlägt fehl
Asterisk Log:
– Called SIP/mdc_trunk_conf-3/**********
– Executing @mdc_outgoing:1] Set("Local/@mdc_outgoing-3dd6;2", “MDC_INPREFIX_TRUNK=0”) in new stack
– Executing @mdc_outgoing:2] Verbose("Local/@mdc_outgoing-3dd6;2", “1,remove inprefix: 0”) in new stack
remove inprefix: 0
– Executing @mdc_outgoing:3] Goto("Local/@mdc_outgoing-3dd6;2", “mdc_outgoing-6,,1") in new stack
– Goto (mdc_outgoing-6,
,1)
– Executing @mdc_outgoing-6:1] Gosub("Local/@mdc_outgoing-3dd6;2”, “sub_trunk-outgoing-6,,1") in new stack
– Executing @sub_trunk-outgoing-6:1] Gosub("Local/@mdc_outgoing-3dd6;2", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,
,00,49,0,2266)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“Local/@mdc_outgoing-3dd6;2", “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: ************* - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2266”) in new stack
– Executing [s@sub_int2nat:2] GotoIf("Local/
@mdc_outgoing-3dd6;2”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“Local/@mdc_outgoing-3dd6;2", “0?s-internat,1”) in new stack
– Executing [s@sub_int2nat:4] Set("Local/
@mdc_outgoing-3dd6;2”, “MDC_CALLEE_NUM_NAT=") in new stack
– Executing [s@sub_int2nat:5] Return("Local/
@mdc_outgoing-3dd6;2”, “”) in new stack
– Executing @sub_trunk-outgoing-6:2] Gosub("Local/@mdc_outgoing-3dd6;2", “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,,00,49,0,2266)") in new stack
– Executing [s@sub_nat2int:1] Verbose("Local/
@mdc_outgoing-3dd6;2”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - CALLERID(num): ************* - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2266”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“Local/@mdc_outgoing-3dd6;2", “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf("Local/
@mdc_outgoing-3dd6;2”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“Local/@mdc_outgoing-3dd6;2", “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf("Local/
@mdc_outgoing-3dd6;2”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“Local/@mdc_outgoing-3dd6;2", “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose("Local/
@mdc_outgoing-3dd6;2”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“Local/@mdc_outgoing-3dd6;2", “MDC_CALLEE_NUM_INTERNAT=##########”) in new stack
– Executing [s-nat@sub_nat2int:3] Return("Local/
– Executing @sub_trunk-outgoing-6:3] SIPAddHeader("Local/@mdc_outgoing-3dd6;2", "P-Preferred-Identity: sip:@sipconnect.sipgate.de") in new stack
– Executing @sub_trunk-outgoing-6:4] Verbose("Local/@mdc_outgoing-3dd6;2", “1,Telefon VOIP Gateway 1 - Standardtelefonie”) in new stack
– Executing @sub_trunk-outgoing-6:5] Dial("Local/@mdc_outgoing-3dd6;2", "SIP/mdc_trunk_conf-3/
,t") in new stack
== Using SIP RTP CoS mark 5
– SIP/mdc_trunk_conf-3-0000039b is making progress passing it to Local/@mdc_outgoing-3dd6;2
– Local/
@mdc_outgoing-3dd6;1 is making progress passing it to Local/s@mdc_extphone-1-0a3f;2
– Local/s@mdc_extphone-1-0a3f;1 is making progress passing it to Local/ext-3@mdc_localdevice-3-7bbb;2
– Local/ext-3@mdc_localdevice-3-7bbb;1 is making progress passing it to Local/ext@mdc_locallocation-3-dcdc;2
– Local/ext@mdc_locallocation-3-dcdc;1 is making progress passing it to Local/64@mdc_diallocation-f760;2
– Local/64@mdc_diallocation-f760;1 is making progress passing it to Local/64@mdc_multidial-64-8181;2
– SIP/mdc_trunk_conf-3-0000039a is ringing
– Local/@mdc_outgoing-d112;1 is ringing
– Local/s@mdc_extphone-5-a919;1 is ringing
– Local/ext-7@mdc_localdevice-3-aec0;1 is ringing
– Local/ext@mdc_locallocation-3-dcdc;1 is ringing
– Local/64@mdc_diallocation-f760;1 is ringing
– Local/64@mdc_multidial-64-8181;1 is ringing
– SIP/mdc_trunk_conf-3-0000039a is making progress passing it to Local/
@mdc_outgoing-d112;2
– Local/*********@mdc_outgoing-d112;1 is making progress passing it to Local/s@mdc_extphone-5-a919;2
– Local/s@mdc_extphone-5-a919;1 is making progress passing it to Local/ext-7@mdc_localdevice-3-aec0;2
– Local/ext-7@mdc_localdevice-3-aec0;1 is making progress passing it to Local/ext@mdc_locallocation-3-dcdc;2
– Stopped music on hold on SIP/mdc_trunk_conf-3-00000399
== Spawn extension (sub_main-48, ext, 9) exited non-zero on ‘SIP/mdc_trunk_conf-3-00000399’
– Executing [h@sub_main-48:1] Macro(“SIP/mdc_trunk_conf-3-00000399”, “hangup,int,”) in new stack
– Executing [s@macro-hangup:1] NoOp(“SIP/mdc_trunk_conf-3-00000399”, ">>>macro-hangup:: EXTEN: int DIALSTATUS: QUEUESTATUS: ") in new stack
== Spawn extension (mdc_multidial-64, 64, 3) exited non-zero on ‘Local/64@mdc_multidial-64-8181;2’
== Spawn extension (mdc_diallocation, static, 1) exited non-zero on ‘Local/64@mdc_diallocation-f760;2’
== Spawn extension (mdc_locallocation-3, ext, 1) exited non-zero on ‘Local/ext@mdc_locallocation-3-dcdc;2’
== Spawn extension (mdc_localdevice-3, ext-3, 2) exited non-zero on ‘Local/ext-3@mdc_localdevice-3-7bbb;2’
== Spawn extension (mdc_localdevice-3, ext-7, 2) exited non-zero on ‘Local/ext-7@mdc_localdevice-3-aec0;2’
== Spawn extension (mdc_extphone-1, s, 1) exited non-zero on ‘Local/s@mdc_extphone-1-0a3f;2’
== Spawn extension (mdc_extphone-5, s, 1) exited non-zero on ‘Local/s@mdc_extphone-5-a919;2’
== Spawn extension (sub_trunk-outgoing-6, , 5) exited non-zero on 'Local/@mdc_outgoing-3dd6;2’
== Spawn extension (sub_trunk-outgoing-6, , 5) exited non-zero on 'Local/@mdc_outgoing-d112;2’
tele
CLI>
  • Ausgehende Anrufe werden immer auf die Zentrale geleitet
  • IVR erkennt keine Tasten an sondern nutzt immer die “t” Nummer
Moin Rene,
hast Du eine Community Version im Einsatz?
Wieviele Ämter hast Du definiert?
Könntest Du für das Amt, um das es hier geht, einmal einen Screenshot der Definition der abgehenden Rufe posten?
Und ein Screenshot der IVR Definition wäre auch nicht schlecht.
Stefan
So tut mir leid für die späte Antwort, aber ich bin grade erst von der Arbeit wieder zurück gekommen.
Ich nutze die Community Version und lasse das ganze über eine “KVM Maschiene” laufen auf einen
meiner Cluster.
Screenshots:
Nicht wundern warum die Ansage “Star” ist. (Nur zum Testen)
Hi Rene,
da fehlt noch was:
Stefan
Tut mir leid hier:
Ein Amt und mehr soll es auch nicht werden.
Hi Rene,
Tippfehler werden nicht dadurch besser, dass man sie zweimal schreibt: Ich wollte die eingehende Regel haben - sorry.
Stefan
So besser?
